86 944 turbo wheel fit?
Will these fit an 86 944T (951)
Specs:
Serial: F116A11 160320360
Bolt pattern: 5x130
Rear: 17x9.5 / 2" lip / 7.5" barrel / 50mm offset / Pilot Sport Cup 255/40
Front: 17x8 / 1.5" lip / 6.5" barrel / 43mm offset / Pilot Sport Cup 225/45
Specs:
Bolt pattern: 5x130
Ditto, will fit an 86 with spacers. For daily driving, I'm currently running 17x8.5" with 50mm offset all around. I'm using 28mm spacers on the rear and 21mm spacers on the front. Those spacers may not work perfectly for those wheels, but you get the idea. I use bolt-on spacers, not slip-on spacers (which would require pressing new, longer studs into the hubs).
