Modified clutch disc
So I was looking for a 930 disc to utilize all of the facing on the flywheel and pp. Went to a clutch and brake place where we buy rebuilt clutches for semi trucks. They are going to put new material on my old stock disc, but instead of stock size it will be wider like the 930. I have had them install new material in other discs before without problems, and never had a problem with their rebuilt semi truck clutches, so I trust their work. Anyone ever done this before? I should have the final price and the disc back next week sometime. Also, they said the dampen springs were a little loose, but they have a special tool to stretch them back out, so no problems there either.
Thicker? I would not make the clutch thicker. Anything thicker than 8.5mm is a risk of not having the clutch disengage.
And it isn't exactly the type of job you want to do twice...
You may choose a different material (metallic or ceramic), or you may choose to modify the pressure plate for greater clamping force. But thicker? I don't see the benefit. These are pretty good clutches, and unless you're racing, you should get a few years out of your clutch....
Tom, I know exactly what you are talking about with the springs, that is a very common thing with the semi truck clutches. It is a true 951 disc, but I trust their judgement with the springs.
Lee, the disc material will not necessarily be thicker, but wider. Basically we are making the 951 disc match the 930 disc. From what they told me, ceramic is not an option for this disc because of the way it is made. But, if I had a disc that was originally ceramic, they would be able to install new ceramic pads on it.
