LSD Oil Cooler Drive Gears 016 115 165
I took a spare LSD differential cooler drive gear 016115165 to a gear manufacturer that I do business with.
They can make these gears for $220 each, if I can can get a minimum order of 10 gears. These parts 016115165 are obsolete and are virtually unattainable. They are mounted to the Ring gear (differential) via 4-small 8mm allen head bolts.
Mine got shredded when the pinion shaft broke a tooth at Sebring. I have tried every supplier, all to no avail.
Anyone interested in buying these in a group sale??
