Vitesse Racing VR-DISPLAY
Old 10-23-2012 | 01:29 AM
Mancuso's Avatar
Mancuso
Default Vitesse Racing VR-DISPLAY
Greetings!
Well, I've installed a gizmo/addon that I think is really worthy of mention. The VR-DISPLAY!
As you can tell from my signature, I have quite a bit of Vitesse Racing equipment so it only made sense to get this little nugget of joy as well. Quite simply, it is a data display/readout for your Vitesse piggyback.
I use the VR-DISPLAY to monitor AF/Lambda, vac/boost, temperature, engine RPM, et al. I have it temporarily placed near the glovebox (see picture), but it can be mounted anywhere. Since the information on the display can be mirrored or inverted (via software), you can use it as a heads-up display (HUD) that reflects on your windshield. This sucker is bright but can be easily adjusted.
All you have to do is select via software what you want to display and you can toggle between the information with a simple momentary switch installed in-line.
Old 10-23-2012 | 09:38 AM
turbo944's Avatar
turbo944
Very cool....have always liked the idea of a HUD display for certain items...
Quick Reply: Vitesse Racing VR-DISPLAY
