Do 16'' Flat Dish Wheels fit over M030 (tried searching)
Searched but no love. I know some 16'' wheels do not fit over S4 brakes (big blacks) and not hit the M030 suspension. This is for my 89 Turbo.
Do 16'' Flat Dish wheels (7'' and 8'') fit without spacers and look reasonable? Looking for winter wheels and these are pretty inexpensive, and forged.
Ben, the 7" Flat Dish has the same offset as the 7" Club Sport, ET65.
The 8" Flat Dish offset is ET52.3, which gives 21mm more clearance from the suspension side and 5mm more fender clearance compared to the 9" CS rears.
These Flat Dish are OE wheels for the 928S4. Unless the 928 front brake rotors/ hubs have different spacing, I would GUESS they'd fit...
Confirmation anyone?
BTW, for my winter tires I use 7" CS wheels at each corner with 21mm spacers and 64mm studs for the back set. 205/55, 225/50 front and back.
Post #11 in this thread shows my winter set, https://rennlist.com/forums/924-931-...ml#post8180482
Hope this helps.
Good to know. Thank you both! I was going to run 4x CS wheels for snows, the spacers are just for looks in the back, right 951saga? I think they bolted up just fine.
