My version of the center console gauge panel
So - what did you do with your old trim rings? How do they mount? I'm going to have to dig up one of your posts so I can take a better look how the rings look.
Stepping the plates is a good idea. I'm going to have to ponder that for a while. I don't know if they can radius the edge or not. I guess the questions remains - is it worth the effort, or does it look good enough now?
Honestly, it looks great as is. I'm sure it's less obvious in the real world, it just stand out a bit more when you take a picture head on with good lighting. And, in truty, it's the radio that doesn't fill the space, not your gauges.
Interior is mostly wrapped up. I still have to install the back seat cubby and clean up some adhesive overspray. Overall I'm very happy with how it turned out. Of course, it took longer than expected, cost more than anticipated and there are a couple of things I have to go back and fix. Yes, I'm aware that my radio says "GPS error". I didn't reinstall the antenna - I'm not sure where to put it now. Before I hid it in the gauge pillar pod.
I bought enough Alcantara to cover the A-pillar trim and front header panel, but I haven't done it yet. I'm debating if I want to or not. My worry is it'll be too much and make the sunvisors stick out like sore thumbs. I used microsuede for the headliner, but I haven't done the sunroof panel yet - I've been hoping for a new Saratoga top!
I originally did my A-Pillars with the headliner material you can get at a fabric shop, as well as the header panel, etc. but never got around to doing the sunroof itself. Ended up going back to the stock vinyl a-pillars, etc. (I had bought a spare set). I cleaned them and sprayed them with SEM low luster clear and it made the sheen match the leather dash a bit better.
I'm happy for now, although you're right, with a Saratoga top one wouldn't have to do the sunroof...
Personally, I'm not a fan of the trim rings either. But the console gauge cluster didn't look right without them and I had to tie the look together. I'm going to get in touch with the guy who sells them to see if he has anything that will fit in my console. They're pretty close, but I'd like for them to be exact.
Maybe I need to change mine out to black.
Once you go black (carpet) you'll never go back...
Curt: Maybe buy a spare set of a-pillars to experiment on? As I recall they're fairly cheap on Ebay. Let me look at the ones I put the foam backed headliner material on, if I can get it off fairly cleanly I can send it to you to play with?
I've been wanting to do the tops of my doors in leather to match the dash as well and have the leather to do it but the 968 door cards have some interesting curves that I think will require a pro to install properly.
Alcantara is really expensive - I don't want to waste it experimenting. My current trim pieces aren't in the best shape, so maybe I'll strip off the foam backing from some of the headliner material and experiment with it first.
How are the 968 door cards different? I have the 944 10-speaker door cards in mine - I thought the main differences were the 968 used round tweeter grills and the door pockets were deeper (and actually useful).
The best part of the 968 door cards is that the upper part is curved and not so angular, so if you rest your arm on it, its much more comfortable. Out side of that, the tweeter is slightly different but not much else is.
Regards, ...Scott
Regards, ...Scott
Scott nailed that point. Drive across the country from Cali to Fla and you will FEEL his point. Freaking SUX! Curt, your car looks GREAT! Well done!
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
A couple of things to think about (I have done quite a few of these) –
Whatever gauge you put on the right side will be obscured by the shift **** for a lot of the time. Depending on your driving position you will hardly ever see it!
www.frontpanelexpress.com is a great resource!
The actual panel opening is not a rectangle – it is slightly narrower at the bottom.
