Another No Start Problem.......
I have a 86 951 here with a no start issue, wiring harness was shot as always so i rewired it and also changed the speed sensor to a new bosch one. I found it destroyed due to wrong gaping. Both sensors are reading 1k ohms.
1.) Harness rewired
2.) New Speed sensor and now both have 1k ohms
3.) I do get spark and fuel when cranking but no tach bounce.
P.S. I do have another running 86 951 here to swap parts from if i need to, prefer not to...
I was wondering if I can hard wire both harnesses to one sensor and see if it starts..?
1.) Harness rewired
Heres some great info from ECU doctors, (they are on here), about testing the speed and ref sensors at the harness into the ECU
http://www.ecudoctors.com/home-porsc...nsor-test.html
Ok, only get spark and signal at fuel injectors in the split second when you stop cranking with the starter and the engine is still rotating(split second). So basically when cranking theres no injector signal or spark, but when off the starter even the tach bounces a bit.
I never bothered changing the relay because i tested for both DME power supplies and they have power constantly key on cranking or not. Now will try from a push start bc it seems when the starter is engaged it stops spark and signal to the injectors......
I cut off a section that was shorting them out and put in new wires all color coated like factory. Tried sensors both ways. Car did not start from a push start. But for some reason when letting off the key to start it the spark plug that I checking with will spark once and niod led light connected to one injector will blink once or twice. I am really out of ideas...........................
