Need IAC advice
Need IAC advice
originally, the A/C was a delete and when i had the engine rebuilt i re-added it, however i need the IAC (motor/valve not sure) for my '86 944 turbo to prevent stalling..
i'm running an electromotive tec-s that it'll have to wire up to..
problem is, i'm not sure what to get etc. do i need the motor and vavle, or just the valve etc?
I was also under the impression that i could go with a late model GM hose type (in/out)..
does electromotive have a generic IAC?
has anyone had experience with this, and if so, advice?
thanks man, but after a lot of searching etc trying to figure this out, evidently Jeff over at Electromotive has the exact part as well as the connectors and harness etc..
i appreciate your help
