Divided turbine housings..
Old 08-13-2012, 06:12 AM
thingo
thingo's Avatar
I think they will be a lot more compact from what he indicated to me, what they showed last year was just a rushed prototype.I expect they will be similar in size to the EFR turbine housings(also stainless), so more compact and lighter.
Old 08-13-2012, 08:19 AM
333pg333
333pg333's Avatar
Originally Posted by Paulyy
Shed some info in the BW turbos you're talking about? Link?
It's the Borg Warner EFR turbos that Rod's alluding to here. Wasn't Nemo using one? They seem rare as hen's teeth which adds to the allure. What's the latest Rod, you're always up with these sorts of things?
Old 08-13-2012, 08:59 AM
thingo
thingo's Avatar
They are around, the sierra sierra used one as well (same 8374 size I think), but still not in easy supply, I think they had a few production problems, and I think indycar using them soaked up a lot of production as well. Turbo manufacturers seem to move very slowly. They keep saying soon....
Old 08-13-2012, 10:41 AM
Duke
Duke's Avatar
Just a note, Sierra Sierra used the 9180 last year. Apparently around 800 awhp.
Old 08-13-2012, 04:29 PM
95ONE
95ONE's Avatar
i was thinking of just getting a .62 TiAL housing and swap it but i'm worried that i'll loose my top end.
I doubt i will really.
Pauly, What is your peak hp? If Its 425 or below, I highly suggest the .63 Tial. It will be
ABSO-FU$$ING-LUTELY amazing. You'll love it. No where near as expensive as a true dual inlet, but HUGE gains in spool time. (from a .82)
Old 08-13-2012, 05:36 PM
dnovak
dnovak's Avatar
.84 T3 will be fine
.62 T3 will be better
Old 08-14-2012, 04:50 AM
Paulyy
Professional Hoon
Paulyy's Avatar
the outlet is quite long on the EFR, would that fit on the 951?
not sure what the actual peak hp is, but i got 3.84v on the M-tune maf at 6200 rpm untill i find time to go to a dyno or josh releases the maf flow sheet i'll never know. but i do know is it's around ~375 rwhp is what josh reckons.
If i change turbine housings, i'll probably go something extreem and aim for a more flatter torque curve if anything.
Old 08-14-2012, 02:54 PM
95ONE
95ONE's Avatar
.63 A/R can supply those numbers easy. What A/R are you running now?
Old 08-14-2012, 04:24 PM
Duke
Duke's Avatar
I ran a 0.83 T3 a/r on a 2.5l 8v for some time and it is laggy. I see no reason to go above 0.63 on a 2.5l unless aiming for 500+ hp.
Old 08-14-2012, 05:05 PM
Thom
Thom's Avatar
I run a GTX3076R with a 0.83 Tial turbne housing on a 3.0 with stock cam and see 15psi at ~3400rpm when controlling boost in open loop.
I can only imagine the very same turbo to be annoyingly laggy on a 2.5.
Old 08-14-2012, 05:13 PM
Scott H
Scott H's Avatar
Paulyy, didn't you originally want to run the .63 Tial, but there were none in stock at the time?
Old 08-14-2012, 06:47 PM
Paulyy
Professional Hoon
Paulyy's Avatar
That is correct. they had supply issues with the .63 at the time.
.82
IICR you had the gt3582R on the 2.5? or i'm thinking of someone else.
Old 08-14-2012, 06:50 PM
Paulyy
Professional Hoon
Paulyy's Avatar
In 3rd i get 15 psi at ~3500rpm which really isn't that bad?
Old 08-14-2012, 06:53 PM
Duke
Duke's Avatar
.82
Yes.
Old 08-14-2012, 07:21 PM
Paulyy
Professional Hoon
Paulyy's Avatar
Yes.
wouldn't that be a slightly different story 'apples oranges' as the gt3076r has a 60mm turbine and the gt3582r has a 68mm turbine which is larger.
looking at the housing size flow rates, the gt30 .82 flows at 23-24 lb/min while the gt35 .63 flows at a very similar 22-23 lb/min
Quick Reply: Divided turbine housings..
