Oil Filter Housing Lower Sleeve Removal Help
Trying to remove the lower sleeve from the block to install in my new block. This is NOT the sleeve with the two o-rings but the one below for the OPRV. Any input would be appreciated.
Found a thread that says sleeve is pressed in and remove with vise-grips. Obviously this will destroy the sleeve and I will need a new one. Thread said throw new sleeve in the freezer then install.
Stuff like this keeps holding me up.
