Question for those running 18" wheels and tires
Old 07-13-2012, 04:47 PM
ehall
ehall's Avatar
Default Question for those running 18" wheels and tires
On the street, what tire pressures are you running? I'm running 285/30/18's rear and 255/35/18 fronts. I'm not sure what the "ideal" pressure should be, or if there is such a thing, so I'd like to get a feel of whose doing what and the results. Thanks !
Old 07-13-2012, 04:59 PM
pat056
pat056's Avatar
I run recommended pressure on door. 36 front 44 rear.
Old 07-13-2012, 05:00 PM
JohnKoaWood
JohnKoaWood's Avatar
How about something aproaching what is printed on the side of your tire?
Adjust down from there?
I have run everything from 15 inch stock PDs to 18 inch MY02s and have stuck to what printed on the tire... if on track and trying to maximize the performance (by monitoring the tire temps between laps / alignment to equalize temps and pressures on track) that is one thing... but on the street you are trying to balance performance, handling, and tire life... which is what the numbers imprinted on teh tires is for...
Old 07-13-2012, 05:12 PM
ehall
ehall's Avatar
As for the numbers on the car door, those were put in place for 205/50/16's and 225/45/16's, or there about. So, to some extent, they go out the window. As for what's printed on the tire, it only shows MAX pressure, not suggested pressure, so YEAH! what else ya got?
Old 07-13-2012, 05:14 PM
ehall
ehall's Avatar
Oh, Pat, the smartass tone was meant for JoKA, not you. I haven't smartassed him in far too long!
Old 07-13-2012, 05:18 PM
JohnKoaWood
Start at the max, down from there till your road feel is on the mark.
And remember, there is a fine line between smart *** and dumb ***.... careful you dont fall over it!
Old 07-13-2012, 05:22 PM
ehall
ehall's Avatar
I always know when I get to dumbass, because I'll trip over you.
Old 07-13-2012, 05:35 PM
pontifex4
pontifex4's Avatar
Sorry, what was the question?
Old 07-13-2012, 05:37 PM
ehall
ehall's Avatar
Originally Posted by pontifex4
36-24-36.
Yeah, but what about the 4th tire?
Old 07-13-2012, 05:39 PM
JohnKoaWood
36-24-36.
Only you would infer a spare tire with that!
Old 07-13-2012, 05:57 PM
racerxrick
racerxrick's Avatar
Agreed on both points. I run nearly the same size tire though 245's on the front. At 33psi I seem to get an even contact patch and wear.
Now if I could just stop bending the lips on thses CCW's...
Old 07-13-2012, 06:02 PM
ehall
ehall's Avatar
My spare tire fits perfectly in the 24 area.
Old 07-13-2012, 06:03 PM
ehall
ehall's Avatar
Thanks Rick. yeah, I'm a bit concerned about my new wheels, but I got them for a steal, so I'll live with it.
Old 07-13-2012, 06:13 PM
gregeast
gregeast's Avatar
Funny, I was about to ask the same question. I may try posting on the 996 or 997 board to see what their door jams say. Same wheels and roughly same weight, right?
Old 07-13-2012, 06:16 PM
gregeast
gregeast's Avatar
Did a quick search on the 996 board and found this:
"I just want to confirm that regardless of brand and model of tire, the cold pressure should be at the PSI listed on the inside of the fuel door.
In my case, 18" 36 PSI front, 44 PSI rear."
Our cars obviously don't have the rear weight bias of a 911 so I'm thinking 36 PSI all the way around. That's a bit higher than I've been running, I'm usually at 34 or so.
Quick Reply: Question for those running 18" wheels and tires
