FS; Koni adjustable rears and Hollow 30mm torsion bars
Since I'm going full coil over, I no longer need these.
I've had the Koni's for quite a while, but of course I build more than I drive. They truly have less than 1,000 miles on them. Not worn out piles like on ebay.
$150 for the pair.
The Sway away powerbarz are Hollow 30mm. Hollow is certainly lighter, but slightly more expensive. I just put my dial calipers on them, read 30.25mm. $205 for the pair.
$150 for the pair.
I know.. I know. The honest answer. I've been building it for 3 years. Installing coil overs on the rear is just an easy last thing to do. I have coilover fronts. But they are JIC's. This combo in the back worked so well with the fronts, I couldn't believe it myself. So I left it. Honest! Bump walk was another story though.
The Koni's are sold.
Make offer on Hollow Torsion bars. These have an effective rate of 380lbs. They did not feel as stiff as I thought they would. They matched well with my 425lb fronts.
