Intermittent charging
I've observed my 951 appears to have an intermittent charging issue.
Haven't pulled the alternator to check it yet, but the intermittent (mostly not)
has me a little baffled.
checked wiring - and it is nice and tight.
I'm observing the issue by monitoring the voltage on the dash instrument panel.
The non-charging light never lights.
Thinking it might be a regulator that heats up then stops, cools off,
then starts charging -- but it doesn't always start charging even
when starting -- but other times it does.
before I rip into the alternator -- figured I'd ask around first.
See if anyone has been there done that.
mike
mike
check resistance between the positive battery terminal and the alternator nut. If its more than .08 or so, clean off your battery terminal and cable. (Do the same for your ground cable) If that doesn't work, you have a bad cable that needs to be changed.
I'm sorry if this is pointing out the obvious, but maybe the battery is shot. Everything apparently working but the battery won't charge are exactly the symptoms I have experienced.
My 85.5 N/A was doing the same thing, I'd get weird reaqdings on a DVOM. Easy fix!
I took it in and the tech checked it and he was kinda like "it's the voltage regulator you dork!
Really worn votage regulator,lbushings and they were making and losing contact!
