Braided fuel lines
Braided fuel lines
Hey guys I have been looking at some of the braided fuel line kits, just the engine bay ones and the jumper line, but they seem kind of expensive, is there a way to make up my own kit with off the shelf parts from someone like summit?
Do I need special tools to cut the lines to size? What parts will I need?
Kim
Kim
You can, but it will cost around the same. Just buy these: http://www.ebay.com/itm/Porsche-86-8...item3a75ed6b54
From: Hawkinsville / Perry, Georgia, RETIRED USAF GO BLUE
I'm not all that crazy about the S/S wire braided fuel lines. You can not inspect them for a leak starting at the connection points until fuel is flowing and creating a fire hazard. S/S Braided Lines add a bling factor, but are primarily to prevent lines from chaffing together. the ones below, IMHO, are a much better set of Fuel Lines to check for leaks.
http://www.rennbay.com/fuel-hose-rep...67db19b781ff7e
Cheers,
Larry
Cheers,
Larry
These guys have all kinds of plumbing stuff for race cars. They also will send you a great paper catalog in addition to their online site.
www.pegasusautoracing.com
http://arnnworx.com/fuel_lines.htm
He has the fittings and everything you need to know to for DIY fuel lines. Not sure if it's not easier cheaper to just get the Rennbay kit..but here you go!
