Okay I need the masters analisys #2 rod bearing failure & #4 blown HG failure
Basic Sponsor
okay let's hear the hypothesis behind the two major problems with the 944 block # 2 rod bearing failure and # 4 blown HG. I want to compile your experience or theory why these two fail so often.
I remember reading this on Lindsey website with the 'steam vent kit' about the head gasket. no experience myself with either of the 2 though.
http://www.lindseyracing.com/LR/Parts/STEAMVENT.html
aren't those almost universally associated with secondary systems failures. I mean, if the rodn gets chomped, ....umm the rest of this is academic! What ate the rod? What actually, of which you have physical ecidence, happened? Not trying to ne a wize ***....thoiugh you KNOW that I would, just asking?
Basic Sponsor
Basic Sponsor
Basic Sponsor
Basic Sponsor
Basic Sponsor
I don't know that there have been enough people with drilled cranks running them in high RPM/high load (racing for example) over the years to really assess the effectiveness.
Maybe you would enlighten us to your desired use?
No I was just thinking about the oils path...which I do not yet know.
Well now this has been posted:
The number 2 bearing shares lubrication with the driver side balance shaft and turbo.
Your question is a good one.....You know more about these engines than me but now you have me thinking and also wanting to know the possible answer.
I have the steam vent kit and cross drilled crank. If I ever get that failure in the future means they didn't stop the problem![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
My car is steet use only since Calgary no longer has a track
I'm not pushing my car hard like track use does.
I am tempted to put a window in one of my spare oil pans to see what goes on with the engine running. I will be buying a car hoist for my new house in August to fit 3 cars allowing me to look underneath while running. No idea if I would be wasting my time but what the hell...its not going to hurt to try.
