Cheap, small battery suggestion for 951 race car
Old 05-29-2012 | 12:14 PM
MarkRobinson's Avatar
MarkRobinson
Default Cheap, small battery suggestion for 951 race car
Hi guys,
I need to buy a battery for a car I'm selling for a buddy: gutted '86 widebody 951 race car. I know you can use really small batteries, but don't want something that someone will have to constantly keep hooked up to a trickle charger, & don't want/need to spend $100 on a 30lb battery:
Walmart/AutoZone suggestions??
Thanks,
Mark
Old 05-29-2012 | 12:39 PM
Van's Avatar
Van
I've seen riding mower batteries used... Personally, I've been very happy with my Odyssey - but it's more than $100.
Old 05-29-2012 | 12:44 PM
rlm328's Avatar
rlm328
I had a wheel chair battery ($40 to $50). For a couple of years. Agree with above I now hae an Odessey (sp?)
Old 05-29-2012 | 12:49 PM
JustinL's Avatar
JustinL
I tried Shorai and it didn't last one season. Friend had the same experience as me, so I would stay away until they sort them out a bit better. When it worked it was amazing and weighed almost nothing.
Old 05-29-2012 | 12:52 PM
400hp944's Avatar
400hp944
PM Tony G or maybe he will chime in. He is using what I believe to be a Harley motorcycle battery in his track car.
Old 05-30-2012 | 02:33 AM
Dave W.'s Avatar
Dave W.
Batteryspec.com
BAB26-12 or BAB30-12
Old 05-30-2012 | 03:07 AM
95ONE's Avatar
95ONE
I used the odyssey for a bit. 220 cca isn't much though and barely started my motor if it was cold. (takes a few more cranks than a warm day.) Harsh news on the Shorai. I just bought one.
Old 05-30-2012 | 04:31 AM
Dave W.'s Avatar
Dave W.
BAB22-12 is the same size and same weight as the Oddysey PC680, but half the price.
http://www.batteryspec.com/cgi-bin/c...ink&product=22
If you still have stock radio, amps, afterrun turbo coolant pump, and alarm, get a larger battery.
Old 05-30-2012 | 12:03 PM
MarkRobinson
Yeah, I might put my battery in the race car as it's 3 years old already (standard 944 battery) & just go with a new one...or keep mine & put a cheapo in it: it's gotta kill switch so that'll help.
Old 05-30-2012 | 12:41 PM
JustinL's Avatar
JustinL
I'm going to try another one too, but this time I'm going to use more foam to try to isolate more vibration... don't know if that will make a lick of difference though.
Old 05-30-2012 | 01:33 PM
TonyG's Avatar
TonyG
Rennlist Junkie Forever
There's nothing wrong with the Shorai. They are great.
If you have a problem with it, it's because your output voltage from the alternator is too low. These are Lipo batteries and will die quickly if the voltage drops too low. I think with the Shorai it's 13.5V. That said, you can tweak the alternator out put so that this doesn't occur.
TonyG
Old 05-31-2012 | 03:45 AM
theedge's Avatar
theedge
NAPA, Deka ETX18L or smaller if you like.
Old 05-31-2012 | 12:21 PM
MarkRobinson
So a 300cca battery works at least: that's good to know.
Mark
Old 05-31-2012 | 12:37 PM
XR4Tim's Avatar
XR4Tim
I have an Odyssey in my Typhoon (rear mounted), and if it's not fully charged, it won't crank the engine over. It's a nice size, but I'll be looking at stronger batteries soon.
Old 05-31-2012 | 11:16 PM
95ONE's Avatar
95ONE
Xsdwe
I just went over the shorai web site and specs. The battery cannot take a charge using more than 24 amps. Our alternators are way more. I'm pretty sure this is the problem. I might rig the battery up with a clamped charge load of 20 amps with some magic circuitry. I think I will run a 16 volt alternator to solve my fuel delivery needs. (fuel pump flows crazy at 16-18volts) That will also run my ignition, water pump, and fans with that voltage. I will install a step down for all the accessories. That's the game plan for now anyway. Its a work in progress.
Quick Reply: Cheap, small battery suggestion for 951 race car
