23mm Rear Wheel Spacers on Turbo S
Just wondering if anyone has run a 23mm spacer on a late offset Turbo S with 9x16 CS wheels and 245/45 tyres?
I have 7mm shims on now and have measured. 15mm spacers would clearly be ok, 20mm looks just ok but I wonder if 23mm is a bridge too far.
a) I already have CS wheels
b) I like the CS wheels
c) Pretty much any replacement wheel is going to weigh more than the combined weight of the forged CS wheel + a 23mm spacer (have you felt how light the CS wheels are?)
d) The stress on the bearings etc ("the 25 yr old suspension components") of 9x16 CS wheel + spacer is just the same as the stress of a "properly fitting" wheel with 23mm more offset (think of the leverage - its the same)
e) Its only 23mm of spacer, right - they are not that big (again, think of the leverage)
