Zeitronix Log
Zeitronix Log
After going to the dyno on Thursday and having a vacuum hose pop off under boost, my laptop crashing and the car just running way too lean, Joshua (Rogue) told me to change the FQS to position 3. Here are the results after a quick run.
My RPM's are way off. Need to adjust the RPM settings in the zeitronix next time I do some logging.
Was this like this the other night? looks like wiring. Check green wire, connects to DME pin 21 (green/black, RPM signal)
That was my thought too. What did you wire the rpm input to? AFR looks ok -- though can't really tell how rich it is getting up top or at what RPM. Zeitronix should think about putting a scale on their data logging screens so you could make more use of a snap shot like this...
Tom, I looked on your site last night. I'll pull the DME and see how its wired and see if its something I want to do myself or have my mechanic fix it. Thanks.
