FQS operation
If I set the (stock chip) FQS switch to reduce timing and add fuel (for whatever reason) does the timing and fuel get changed for closed loop or only open loop? Or does timing change open or closed but fuel only open?
It applies to both. In closed loop, the DME will try and keep the AFR dittering around 14.7/1 but it has a range limit.
http://www.motronic.ws/lambda.htm
So the seed values are increased or decreased according to the switch position and reducing timing for a NOX issue only works if you can get them to test the 15 mph rolling test in first gear.
Thank you very much.
