House Automotive BEWARE!
Basic Sponsor
Okay just to show the fine work of House automotive
I am missing the wastegate, the wastegate dump pipe and elbow tie pipe.
the tranny was bolted but the tranny support crossmember was left out?, at first I questioned the reason why, than I realized that they had broken the right side bolt for the tranny support crossmember, this is the first time I see one of this snapped that's a sturdy bolt, any suggestion how to extract it? I have the sears drill extractor set or do I drill it out with a regular drill bit
Basic Sponsor
got the bolt out what a PITA, do you think they did this in purpose?
Lart, thanks so much for your hard work. I know how much of a pain extracting broken bolts can be. I wouldn't be surprised if they had bad intentions towards my car after they found out I'd be pulling my car from their shop. I was fooled by the friendliness of their staff only to find that their techs are just a bunch of incompetents.
Basic Sponsor
good thing is that I should have the car ready by tuesday morning
Basic Sponsor
shifter leather booth is all there, finished the hooking the axles, also the replacement wastegate, dump pipe and small tie elbow pipe, installed the front sway bar, all that is needed is to refill the transmission and bleed the clutch and it's done worked on the car until 9pm tonight started about 5pm.You guys notice something unusual in this picture?
Oh good, so you were able to find the leather shifter boot? You guys definitely worked overtime on this car. By the way, I didn't know bibles had 951 specs in the scriptures. Also, the shop should have installed a new tensioner if I'm not mistaken so the one you saw in the box was probably the old one. Thanks again guys, I definitely look forward to seeing her run again.
Basic Sponsor
