Largest Diameter MAF "Tree" possible
Hey all - as I migrate toward a Rogue tune using a 90mm Lightning MAF - I'm trying to reduce the changes in diameter on the intake plumbing to keep the MAF signal clean.
Currently I have a 2.5" MAF "Tree" with the LR MAF II setup. I believe there are larger ones. What is the largest diameter that will fit without major modifications ?? I would like to get at least a 3" - if not a 3.5" dia.
Anyone have one ?
Thanks -
Anyone have one ?
Thanks -
I used to run the Lightning MAF. I fabbed a tree going from 3" to 3.5". Smooth transition.
Attachment 628495Attachment 628494
