FS: 944/951 Parts
#50
@jg951 - If you mean the throttle position sensor, I have one but I'm not sure it is working. I'll throw it in the box I have on the way to you free of charge. It is easy for you to test.
#53
hi,turbocharger and spare parts can be supplied ,like repair kits , bearing housing, rotor assembly,turbo cartridge,turbo housing ,turbo wheel .
SaraHu
tonglint03@tonglint.com
www.china-turbocharger.com
SaraHu
#54
Folks - bumping as many parts still available. See initial post for current list. And if you don't see it there, just ask, as I have a bunch of other miscellaneous stuff.
#55
Do you still have the following:
8. Coolant thermostat, 1 Wahler, 1 unmarked brand. All NEW, - Quantity 3 - $5 each
11. Clutch fork, Used, Qty: 2 - $15 each
12. Clutch fork pin, Used, Qty:2 - $5 each
Can you verify the forks are 951 p/n#'s
#56
Have clutch fork pins.
Have forks. The part numbers are interesting. The two forks look different but have the same key dimensions. One is beefier than the other and a rougher casting. Part numbers appear to start with 931.116.835.xx on both of them. I don't know how interchangeable they are between years and NA vs. Turbo. I suspect these are NA ?
#57
My memory tells me the turbo fork is a 931 p/n#. Can someone verify. If so I would be interested in the 931 fork assuming it is good condition and almost forgot what temps are the T-stats??
#58
