oil pressure gauge bouncing around
when i bought the car the needle was stuck all the way to the top just a few days ago the needle started to jump around and on throttle it stays pined up
If the needle is jumping around really fast, you will want to check the electrical connections between the sending unit and the gauge. The gauge will peg at 5+bar if it looses signal from the sending unit.
If the movement is a little more gradual, it could be an oiling issue. More than likely its electrical though.
Yes. Smallish can shaped thing that treads in to the oil thermostat/filter housing, just below the filter and between the engine an body rail. There will be two wires connected to it. One is for the pressure gauge, the other for the oil pressure warning light.
