3" gasket and turbo seals
I just bought a 3" down pipe and and I'm guessing that I can't just slap it on so what I want to know is what would I need in order to be able to put it on properly. Also while I'm in that area I'm thinking that I should do my turbo seals the question is where can I buy all the seals?
Lindsey Racing sells copper gasket for 3" exhausts or --if you have the patience-- you can make your own out of a sheet of copper using a hole saw, dremel cutting wheel and a grinder. Which downpipe did you get?
For the factory seals, you can go to just about any of the 944-freindly places -- Pelican Parts, Paragon, 944online, Lindsey, Vertex, Zims, etc.
