SOLD: 951 Koni Coilover setup almost new
SOLD
Somebody looking to upgrade their suspension can save some money here. These have only 3k miles on them and are in perfect working condition. This is all 4 corners single adjustable Koni sport's. Here's what's included:
Koni Sport front stuts converted to rebuildable coil overs with new Koni inserts. This is the Paragon kit using all racers edge parts and Koni competition bump stops. Struts were freshly painted yellow and look great. They come assembled and set about 1" lower than stock but are easily adjusted. The strut bodies can also be easily rebuilt in the future with the Koni inserts.
Hypercoil 200lb front springs. These are perfect for stiffening a little bit from stock but not having to change your torsion bars.
Koni Sport adjustable rear shocks.
Spanner wrench to change ride height.
Koni Sport adjustment **** to change stiffness of front struts.
The total cost of this setup from Paragon with everything included is $997 plus shipping.
Selling for $840 shipped. Save a couple hundred bucks and save a bunch of hassle putting stuff together and making sure you have all the pieces.
Uploaded with ImageShack.us
Basic Sponsor
are the hats made for camber plates?
From the Racers Edge Website. I know they work perfectly with the stock strut mounts, but I think they also work with camber plates.
This is an upper coilover spring hat for struts. It is specifically designed with an extended top for the 944 cars that have a recessed upped mounting surface. These hats have a 14mm bore and 22mm counter bore that are a perfect fit for any OEM type strut.
Application: most coil-over struts for use with 2.5” ID race springs
Basic Sponsor
okay, sounds good, I have a local customer interested in a front coilover setup and I will direct him to this thread
