OK thanks, I have the factory DME removed, i am running standalone and I need to wire in my coil packs... I was checking too see if i could use those factory two wires.. but the way it sounds i will have to run my own 12v key switched and tap the tach signal from the harness under the dash... damn.. thanks for the help Brian, you're the man.
The tach signal also comes from the DME. You need to use the ignition driver from your standalone to fire the coil. Remember to fuse the 12V to the coil, I have no idea why Porsche ran a hot wire to the coil.
