951 swap for sale
Complete engine swap with mods. I bought this motor with 80k on it over the summer and did the following.
All new seals
New head gasket and all others gaskets
LR oil pan baffle and gasket
New LR 61 Garrett turbo
LR clutch stage 4
Aluminum flywheel
Rogue tuning M-tune maf kit with injectors. Sick gains when installed!
Tail 38mm waste gate
3bar fuel regulator
New valve stem seals
Dme tuned by rogue tuning
Since the build I put 200 mile on the motor.
I spent over 5k on everything
4300 firm or I'll part out
All new seals
LR clutch stage 4
Aluminum flywheel
3bar fuel regulator
Why did you pull the motor?
All new seals
LR clutch stage 4
Aluminum flywheel
3bar fuel regulator
All new seals
LR clutch stage 4
Aluminum flywheel
3bar fuel regulator
