Dyno Results - Ball and Spring MBC
#46
Small Business Partner
Shawn, tq dropping off is most likely from two things: boost pressure dropping, and flow-restriction...
The boost dropping off has already been noted.
Regarding flow-restriction, the first place that I notice is you are still running stock exhaust, which was designed for a ~200rwhp car!
#48
I am thinking of trying to fix my drop in boost pressure (WG spring, EBC) and see how it looks. Then I will start attacking flow-restrictions and then possibly some timing tweaks.
It is great that I have a dyno a few miles away and that it is only $50 on Thursdays nights. It makes it easy to test different mods and it is also a lot of fun.
#52
Rogue - As always I appreciate your input. I am running a test pipe which is definitely less restrictive but even so your right that I am pushing it , I guess I am trying to get a feel for component limitations before I upgrade.
#53
#54
Josh I love and hate you... or atleast my wallet does... I'm saving to get your fancy injectors and now your throw out your teaser... your a sick man a sick sick man.
Any ETA on said item? roughly
#55
I'm bad at ETAs... springtime
#57
#58
Zeff - Still running the stock down pipe. Cool about your car, lookin forward to seeing the results. Those mods along with what you have already done should make for a very fun car.
#60
P.S. If I don't respond soon I've been killed by an NA owner, I just ask that I be buried naked in a carboard box and funeral will be open casket.
