Battery Relocation
Old 02-22-2012, 04:04 PM
fortysixandtwo
fortysixandtwo's Avatar
Originally Posted by reno808
BTW how did you search?
I've mostly given up on the built in search function. IB broke it when they took over.
This is how a search rennlist now.
Old 02-22-2012, 09:56 PM
Paulyy
Professional Hoon
Paulyy's Avatar
Originally Posted by 86 951 Driver
Get the biggest wire you can that is still flexible. Hook that up to the wires up front run the wires down the torque tube tunnel. Maybe put some wireloom around them for extra protection then run that up into the spare tire well. From there put in a battery box from summit racing or jegs.
If you're planning to run wires under the car, that's a big NO-NO
The + (positive/Red) wire is ran down my car on the side of my passenger side or your drivers side.
Old 02-23-2012, 04:13 AM
Olli Snellman
Olli Snellman's Avatar
We have excatly the same plans as you do. In our case current battery location will be in the future the place where ABS pump ( from Boxster) will be . We are using more or less used and reconditioned "kit" from a UK spec car.
Old 02-23-2012, 08:33 AM
JohnKoaWood
JohnKoaWood's Avatar
Reno..
If you want large gauge flexible cable, let me know a length, and I can hook you up!
Shoot me an email or give me a call.. I can supliment the kit you already have installed, or replace it all together (replacing would be cleaner IMHO)...
Old 02-23-2012, 04:21 PM
Scott H
Scott H's Avatar
Here's a nice place for cheap wire. They're local to me and a fantastic store. It's like the corner of your garage that you shovel all the crap you'll never use, only organized into several thousand very cramped square feet.
http://www.skycraftsurplus.com/weldingwire.aspx
Old 02-23-2012, 04:24 PM
reno808
reno808's Avatar
Originally Posted by JohnKoaWood
Reno..
John i'll give you a call later on
Quick Reply: Battery Relocation
