wideband O2 sensor routing
Starting to install my wideband O2 sensor and was wondering where is the best way to rout the wire through the firewall?
I ran my wires up through the engine bay by the headers then into the battery area and through the firewall there. I was worried about heat on the wires going through the engine bay so I went to my local hot-rod shop and found header wrap to wrap the wires.
Ran mine up over the bell housing and followed the oil fill tube to the top of the firewall. Then routed across by the brake master cylinder and through a grommet over there. Once by the fuse box, i routed it through another grommet into the cabin.
![](http://img.photobucket.com/albums/v120/TechnoDuck/My%201988%20Porsche%20944%20Turbo/IMG_7052.jpg)
