What's my first step?
I bought my first Porsche in August, a beautiful white 1986 951. It has 107,000 miles, and runs, looks and drives like new. It is stock except Weltmeister chips and a K&N filter (I've ordered the factory filter after following one of the discussions on Rennlist). I live in Minnesota, so the car is in my shop for the winter. I plan on replacing the belts, rollers and waterpump, also going through the CV joints. I'm hoping to put in rear seat belts with shoulder harnesses for my 4 year old son. What is my best first performance step? Exhaust? Guru MAP kit? I'm really impressed with the feedback on the MAP kits and Danno's support. I would like to gain as much performance as possible with my stock turbo and without worrying about blowing head gaskets or other carnage. THANKS!!!
Welcome to the club avainio! <img src="graemlins/wave.gif" border="0" alt="[byebye]" /> May I suggest you try our Chip Upgrade Kit first? I think you'll be pleasantly surprized at the performance boost over your existing set-up. This will hold you over as you consider your options. You also get a $250 discount on the MAP kits later since the same components are used in the chip-kit.
We're working up an upgrade plan for people with minimal redundancy. Going from the Stg.1 to Stg.2 kits will be easy with just the J-pipe and larger K&N filter needed. This will also continue to scale up with the GURU-364 kit easily as well...
[quote]Originally posted by Danno:
<strong>Welcome to the club avainio! <img src="graemlins/wave.gif" border="0" alt="[byebye]" /> May I suggest you try our Chip Upgrade Kit first? I think you'll be pleasantly surprized at the performance boost over your existing set-up. This will hold you over as you consider your options. You also get a $250 discount on the MAP kits later since the same components are used in the chip-kit.
We're working up an upgrade plan for people with minimal redundancy. Going from the Stg.1 to Stg.2 kits will be easy with just the J-pipe and larger K&N filter needed. This will also continue to scale up with the GURU-364 kit easily as well... </strong><hr></blockquote>
Aye - grab up the Guru Chip Set - you'll love it. After that, you can grab the MAP kit minus the price of the chips - win/win situation. Youll get performance you can feel from this stuff - if you want to sound fast however - exhaust is the way to go.
Okay Danno - I'll bite...
"This will also continue to scale up with the GURU-364 kit easily as well..."
What gives? New project in the works? Let me guess - something with a new wastegate, turbo, etc... that builds off the Stage II MAP kit? Not nice to tease people like that you know. <img src="graemlins/nono.gif" border="0" alt="[nono]" /> Let's have some details...
Is it a fairly straightforward job to replace the chips? This looks like a very nice way to add performance in several steps, I would definitely want to upgrade to the MAP kit in the future. I can't believe how fast this car is already, just thinking about it is making me cross off calendar days until spring.
I've been following the discussions since I bought the car (and became a card carrying Rennlist member 2 days later), and I'm amazed at the knowledge and willingness to share it on these forums. I'm actually looking forward to changing my timing belts. THANKS AGAIN!
Arne.
Arne.
