Keyless Entry / Exploit Porsche Alarm
I have a late-1986 951. Would like to add keyless entry. If possible I'd like to tap the factory alarm capabilities (if possible).
Any suggestions that won't require a Master Electrician to follow?
Vendor and wiring suggestions greatly appreciated. Thanks! - Mark
done this to my car, fitted a "Thatcham approved alarm" to my own car, which uses the wiring running to the door switch (connected to the lock-**** with the LED in it), it was very easy, basically your alarm will provide a feed to this circuit and will operate the power locks.
Si 951s, chips, shims, Lindsey BE, 17s.
