any boost in neutral, running through RPMs?
Quick silly question: Should I be showing any boost if I'm in neutral, just running the engine through the RPMs up to redline? I was going to be testing my boost problems, and I was hoping to be able to tell if any changes I am making are helping, without putting the car down and driving it around the block. Should I be getting any boost in neutral? Am I an idiot for asking? <img border="0" title="" alt="[Wink]" src="wink.gif" /> Thanks!
You shouldn't show much, if any. The reason for this is that the engine revs much faster than it normally does because the drivetrain isn't attached, so you hit redline before the turbo has enough time to spool fast enough for positive manifold pressure.
