Finished cleaning block for new WF HG. How smooth a finish should I aim for?
#31
When installing the gasket, I always put a VERY thin coat of Ultra Blue RTV around the water return jacket as this area tends to leak even with a stock gasket. (This is simply a skim coat and not a bead). I install the gasket and make sure there is no overlap then carefully set the head on the studs. I also always make sure to give it 20 minutes or so between TQ sequences to give the studs a chance to "relax" a bit.
#32
Thanks for the info Jeremy. The scotch brite pads are great, i used them to clean up the oil pan mating surface earlier this year. Are you installing the gasket dry, with the exception of a sealant around the front water jacket neck?
#33
