Max HP and passing California emissions
Just curious, I'd like to be able to invest some cash in my 951 this summer to squeeze out some horsepower but still want to be able to pass California smog sniffing at the next registration renewal. I think I can find an inspection facility that would live with the visual part of the inspection. It's the emissions test that I'm worried about.
My car is currently running Weltmeister chips, a shimmed wastegate and LBE. I had taken the original cat out and failed during the last emissions test. I put a new used cat in and passed with flying colors.
Any thoughts on what will and won't pass the emissions test here in California?
Well, all the visual inspections should pass without any problems. The one sticking point is the exposed K&N filter. But make them look it up in the book and they'll see that the 944 Turbo is not required to have a TAC-Thermostatic Air Cleaner. All the crankcase gases are vented to the intake-plumbing before the turbo, not the air-cleaner box.
As for actual emissions, you lower your fuel-pressure using an adustable FPR so that it passes cleanly.
Intersting idea, hadn't thought of that.
Could theoretically any chip/turbo/MAF/??? system pass CA emissions testing if an adjustable FPR is set at stock or lower pressure?
You can actually get away with a lot; providing you can still pass the smog tests. See my detailed reply here: <a href="http://forums.rennlist.com/scripts/rennforums/ultimatebb.cgi?ubb=get_topic&f=15&t=004786" target="_blank">Topic: Is ANYTHING aftermarket legal in California?</a>
