Greddy Profec B Boost Controller
Just got mine in the mail today and was reviewing the instructions. Does anyone have a website on how to install this thing or something I can look out to make installation a little easier? The controller itself is so small as the pictures on the net go my thinking it was the size of a car cd deck. Anyways if anyone has a useful site please post it. Ill get some digital pictures of it for you as well and post them later tonight.
Here are some site with install info i found.
I am also getting a profec b, Please tell us if it work good or bad in a 951.
<a href="http://www.rx7turboturbo.com/robrobinette/profec.htm" target="_blank">http://www.rx7turboturbo.com/robrobinette/profec.htm</a>
<a href="http://www.scuderiaciriani.com/rx7/profec_install.html" target="_blank">http://www.scuderiaciriani.com/rx7/profec_install.html</a>
<a href="http://www.greddy.com/profecguide.html" target="_blank">
greddy profec a guide, but also info for profec b
</a>
If i find more info i will post it
Good luck.
p.s. i was planing to by-pass the CV and only us the profec b to controll boost. Plug up the CV and plug in the profec b from the stock bango bolt to the wastgate.
</a>
Good luck.
Would you see any difference in boost response running through the single port wastegate? Like higher boost, quicker spool. I thought you had to go to a dual port wastegate to see any differences. Anybody care to chime in?
p.s Dan I thought you were going to sell your cars?
TIA
KEN LOUIE
86 951
79 930
TIA
KEN LOUIE
86 951
79 930
Ok so i installed a profec b on my 88t and it was pretty easy to install. I by-passed the CV. I plug the profec b in this configuration.
-boost guage hose to greddy control box.
-bango bolt to in port of greddy module.
-out port to wastgate.
-ad power and ground.
Now i'm not finished tuning it yet but i can't seem to properly control a low boost setting to about 12psi??? But i am getting good fast boost response considering i have a completly stock car with a steve r chip.
These are the boost reading i got.
1 gear: 5psi at 3100rpm 13psi 3500rpm drop of to 11psi after 5000rpm
2gear: 14.5psi from 3000rpm to 6500rpm
3gear: 15 psi all the way baby...
4gear: 15-15.5psi up to around 5000rpm than i ran out of road so i can't be sure if it last up to redline. But so far with not a perfect set up and with the boost rising rate set at max, i get great boost response (0-15psi very fast) and stiks
right at 15/15.5 and i don't get any boost spikes.
So i can say i'm happy with it becose it reduces my lag and i hold more boost longer. I will be doing some more testing and taking notes to see if i am really getting longer boost.
