First there was A/C, then Not!
1986 951 A/C worked fine. Stopped abruptly. PRessure seems fine. Master fuse ok. Am I missing soemthing simple? Like auxillary fuse?
Seems electrical, just due to the quickness of the failure.
Did have a lot of vacuum line problems, but assume not related.
Ideas?
Ideas?
Check to see if the compressor clutch is engaging went you turn the A/C on. If it is not, check to see if you have voltage going to the clutch (with the A/C on). If you have voltage, you have a bad compressor clutch.
