methanol injection tuning
Old 12-03-2011, 09:03 AM
azmi951
azmi951's Avatar
Default methanol injection tuning
It has been a while since I posted but I have recently built a methanol injection setup for my car. Anyone know what kind of tuning is needed after installing the system?
Any indication of how much more boost can be run?
I placed the injectors right in front of the throttle body.
Old 12-03-2011, 10:39 AM
ausgeflippt951
ausgeflippt951's Avatar
Your goal is to get this working by the time I get back to Tucson. Did you try asking Carlos Murphy? I think he's done Meth injection.
Old 12-03-2011, 10:58 AM
azmi951
azmi951's Avatar
It works, I just dont know where to go with any tuning needs.
By the way, enjoy the Facebook video if the Sydney Telstra 500 V8 Supercar Race.
Old 12-03-2011, 02:03 PM
toddk911
Drive-by provocation guy
toddk911's Avatar
Talk to Josh with Rogue Tuning. Also with proper a-f and knock counter you should be fine.
Old 03-15-2012, 10:55 AM
Adonay
Adonay's Avatar
Did you ever tune for the meth\water setup or just ran it as is ?
Old 03-15-2012, 01:23 PM
JohnKoaWood
JohnKoaWood's Avatar
ALso not a bad idea to monitor EGT and IAT, but thats just me... I'm a data point geek like that when upping the boost and playing with the timing for things like adding Meth injection...
Old 03-15-2012, 01:49 PM
reno808
reno808's Avatar
I am going to be adding this once my car is all sorted out
Old 03-15-2012, 06:02 PM
Adonay
Adonay's Avatar
Meth injection with E85 should lower the EGT i have been told.
Old 03-15-2012, 06:15 PM
pole position
pole position's Avatar
50/50 or 100% meth you are going to run pig rich without tuning. You need a wideband and timing datalogging equipment, the first tonlean it out , the second to monitor with how much timing advance you are going to get away with.
Meth tuning is very similar to race gas tuning.
Old 03-15-2012, 06:51 PM
Adonay
Adonay's Avatar
I think i will stick to just E85 or gas . I do not really need\want more things to tune and think about.
Old 03-15-2012, 11:21 PM
2bridges
2bridges's Avatar
So ideally you want to spray enough methenol to reduce knock count and not a huge amount over.
Not sure what setup or quantity/size nozzle you have, but single nozzle is typically good to 650HP.
For stock compression 951 i would think around 8-10lbs and above to trigger meth.
depending on setup some will get a bit more agressive with timing as well.
Old 03-16-2012, 03:10 PM
Paulyy
Professional Hoon
Paulyy's Avatar
eBoost2 can trigger meth in many different ways.
i always have 2nd thoughts about meth injection or nos.
just the thought of a 2nd tank full of liquid (more weight) and the problem is, when it runs out, you need to top it up.
The situation i usually think about is that you're on a straight about to over take to gain 1st position and your meth runs out while on full boost, "Bang" your engine sees detonation... and 2 seconds after that you see half of your bottom end in your rear view mirror.
Old 03-16-2012, 04:10 PM
pole position
With a quality failsafe nothing goes bang.....Aquamist is the best.
You can use your windshieldwasherfluid tank if you are concerned with having two containers or just drain that one for track duties and have a dedicated 2 gallon tank in the sparetire area for better weight distribution.
Unless you are running 4 hour enduro races you are not running out of meth on the track.....
Old 03-16-2012, 06:01 PM
333pg333
333pg333's Avatar
If you have access to E85 there isn't a lot of point to this though?
Old 03-16-2012, 06:10 PM
Adonay
Adonay's Avatar
No there is not . Unless going for methanol injection in addition to the E85. It will still cool the charge-air so it serves some purpose.
Quick Reply: methanol injection tuning
