FOR SALE: Huntley Racing Stage III MAF Kit
I'm upgrading to standalone engine management, so the MAF kit has to go.
This is a slightly used (~4K miles) Huntley Racing Stage III MAF kit - generation 2.
With the kit you get:
Link Electrosystems InterceptLink with harness
- Pre-programmed by Derrek from HR personally
- Several hours of dyno time, and "daily driving" used to perfect the mixtures
Stainless Steel intake piping with K&N filter
- In case you haven't seen these, you get a stainless steel intake pipe set that runs from the turbo inlet, towards the drivers side where it has a K&N filter sitting behind the headlight.
- This particular one will mate with a stock turbo (I think HR sells a piece that will let it mate with the turbo of your choice)
MAF wiring harness
- Pretty self-explanitory, this is the harness that runs from the MAF sensor back to the InterceptLink. The harness is abrasion protected.
New, these kits are $1695! Here, it's a steal at $1300.
With a few thousand miles under its belt, the air filter could use a cleaning. Other than that, the whole kit is in tip-top shape, ready to bolt on. I made 285 at the wheels @ 17psi on 91 octane gas with this kit. (295 @ 19 psi with race gas) - all with a STOCK turbo. It works out to about $13/HP - not to mention you're getting 100 of them!
First come, first serve. If you're interested, email me at chris@rcldesign.com
Get it before it goes on EBay.
MAF wiring harness
