hard starter ?
hard starter ?
Well thanks for all your "Hellos" and greetings. i now pose a small question..
When starting. the engine will often crank slow for a few turns then quickly then the car will start. This does not happen all the time and can often fire straight up.. any ideas?
Cheers <img src="graemlins/beerchug.gif" border="0" alt="[cheers]" />
This was my symptom also, and after going thru all sorts of grounding checks, replacing the DME relay, and crossing my fingers every time I started it for a few months, it finally died (clicking only) I replaced the starter this weekend and that turned out to be it. FYI ended up costing less than $200 for a Bosch factory rebuilt.
How old is your battery? Check the terminals and make sure they're clean.
My car sometimes cranks over slowly after not having been run for a few days and I know I'm due for a new battery.....
