Is it just me, or are these pistons whacky?
actually you need at least 4.5 mm shorter pistons in order to get the compresion done AND you have to modify your head.
4mm are not enough and will put your compresion to about 9.5:1
Konstantin
Konstantin
I forgot. the 9,5:1 will be with stock pistons. The shape of the pistons on this pic will give you higher compression. I think Andy is right and thsi is what I wrote on the two rob board many months ago. The car had to high compression.
Konstantin
Konstantin
