fuel injector
fuel injector
i was reading some of the post on high ohm fuel injectors and was left a little confused. can i run a 42lb 14ohm injector and be safe. im upgrading to a k26/8 turbo and already have the maf conversion and pro max chip. just purchased the 86 951 that quite a bit of mods already. my friend wants to try my fuel injectors and has a new set of 42 lb injectors for me to try. my car has the scivision pro max maf and chip. 3" exhaust and down pipe. any info would be greatly appreciated. or an injector to start out with. im assuming my injectors were stock by the part number. thanks
thanks for reply. seeing so many people talking about 55lb and higher assumed the car could take extra fuel. i know im running 13 lbs of boost now. is stock 32lb injector. im just used to working on my hotrod where more fuel just makes it go faster. thanks again
