Brake proportioning valve missing
This is a bit tricky. My Turbo S had too much rear bias even with the proportioning valve. After some testing I ended up with a softer pad in the rear calipers which solved the problem nicely. The classic symptoms will show up on hard threshold braking only. If you feel the rear dancing around, try a little less rear pad.
