Was this fuel line installed correctly?
Had a shop finish up my Rennbay basic fuel line install.
The line in question is the one from the damper to the hard line. See how it is at a ~25 degree angle? It looks like it keeps it off the intake, but I don't remember it being cocked like that...
thoughts? I have to have them redo some work anyway for another issue, didn't know if this was something too...
Thanks RL
*edit*
Ha, found this photo of the original and it is straight... so what gives?
Thanks RL
*edit*
Jumper is about 2 days old. =)
Shop should have told me if the rail should have been replaced, no? Second photo is from the ORIGINAL line, so do not use it as a reference
Days. All 3 lines (Feed, return [Rennbay], Damper [OEM Porsche]) were just replaced Friday. Remember, first pic is new, second pic is original (as per corrosion, and NOT being cocked).
Lart, you may have some trouble getting to the bottom connection if you leave everything installed. I installed mine when I had the rail removed, but I would imagine you could disconnect the line from the rail, and then remove the damper to get to the lower fitting.
Ok, just making sure! I have one sitting around and hate to see old brittle ones on there.
