Throttle Position Switch???
Small Business Partner
Basically, since we use the MAP sensor as an axis for timing, we have programmed in some MAP sensor error checking. The DME constantly checks that the MAP sensor is "believable". It does this by a MAP vs airflow function. If it believes there is too much airflow and not enough pressure, then it will trigger an artificial limiter (like the rev-limit), and limp-home.
If there is an error, then the most likely trigger point is at the transition from vacuum to boost, because this is the point when the MAP sensor reading starts becoming increasingly important.
I had thought that there was enough "allowable error" programmed, as it works great up here (~5000+ feet). But, evidently, those at lower altitude, and especially with the bit thicker air from the cooler weather, are just touching this limiter/limp-home.
Gents, the fix is easy - I simply need to enlarge the allowable airflow range on your Tune.
This is what I am seeing as well, happens in pretty much every gear. When I let off the throttle the rpms will drop, jump up to 1300, and then settle down again... which causes the lurch when crusing along and letting off the throttle. My throttle response was great with my original M-tune, when I upgraded to the #80 injectors and latest software update I started having problems.
I can understand this, but curious as to what constitutes "cold". My car is in a heated garage, so upon starting in the morning, it is at least 70 degrees. Outside temperature this week was in mid 50's in the morning. What would happen say in Michigan outside below freezing? Maybe I need to due some more research on E-85.
E85 will have cold start issues. Just look at the Flash point of Ethanol vs gas and you can see why they sell a blend of 85/15%. Diesel fuel has a higher flash point then Ethanol so they need glow plugs to get the heat in the cylinders. I think E85 will have some issues and people will get us to them. Gas is pretty amazing stuff, great energy vs weight and a very low flash point.
Joshua, I'm going to return the chip you sent along with that old MAF tree pipe on Monday. I'll just wait to do the chip swap until you get the new code in place.
I won't be driving the car for the next week or two anyway. My TO bearing was making a hell of a noise today, so I'm happy to have made it home. I won't be taking it anywhere until it's got a new bearing and clutch .
Yo, I've had my Mtune on the car for about two weeks now. I didn't really get a chance to really evaluate it until this weekend driving down to Atlanta for the Mille event. I am very happy with the performance of the mtune, but I too have had some quirks. After the car is warm it will sometimes hunt for idle at stop lights (drifting up and down from about 800rpm up to 1400) This would happen more often after driving for a while then shutting the car off (gas, food etc) Twice during the trip the car would just increase the idle, revving up to about 3000 as if I was stabbing the gas at a stoplight. All of these seemed to correct itself if I tapped the gas. I originally thought that I had a bad tps also since I had some quirks last fall where my idle would be low, but resetting it from the Lindsey directions fixed it.
Josh - did you ever see my email?
Location: Bangkok, Thailand, Milpitas, CA & Weeki Wachee, FL
1 Post
Zeff
Mine does that too, hopefully corrected with new idle code. I am on vacation in Florida. Hopefully new chip will be waiting for me upon return home next week.
When my idle switch was going bad it would act normal when cold but worked bad when the engine got hot. No amount of adjustment would fix it.
To you guys who have cold start issues with E85, does the car fire up on the first try? Or do you have to crank it a few times before it fires?
It would start, then stall. Second time it would run rough and then smooth out. This was with 40 degree weather. I switched back to gas for the winter and it goes into storage soon.
1 Post
It will not start on the first crank even in 70 degree weather, not on the second most of the time, almost always on third try. Fires up immediately with gas. The thing that worries me a little is the amount of vibration and struggling after it does fire up on e-85. Good thing I recently installed LR ultra mounts.
Mine only runs rough on the first start when it stumbles bad for a few seconds, then stalls. The next time I crank it, it fires immediately then runs relatively smooth while it warms up. Lowest temps so far have been high 30's to low 40's but the car is in the garage which probably isn't going much below 55-60 overnight.
Gents,
I've been doing a lot of work on the idle stuff - especially for the E85 maps. I am nearly done with the new code, and will update everyone as soon as I am finished!
1 Post
The power difference is amazing! Thus the reason I am sticking with the E-85. I am faithful that Josh will take care of us very soon. He is a great guy. I took my friend at work for a ride and he has a new M5 with the V10 and when I lit up the 295's at 40 in second he got scared and said R U kidding me this is a 2.5 liter four?
Yep - a couple of guys are testing it now.
I am doing one more tweak (unrelated) this week, and then will do a mass-update next week.
Expect an email from me near the end of the week.
