Wideband?
Also not that it was brought up but... the Innovate is the only WB 02 I know of that some people have had issues with?
I am refraining from getting into the crazy logging/make your own tune/push past 350hp area. I should be safe and happy with A-Tune and 15psi.
I suppose I could also use my Flip video camera (free, thanks TD Bank) to recover AFR/Fuel Pressure/Boost. =)
On the Audi I have both LC-1 and UEGO wired up. The LC-1 is a complete POS and will be gone soon. Will probably replace with an LM-1 or 034 wideband controller to go allow the EMS to log and still use the UEGO for display only.
951 I have a UEGO along with J&S Safeguard wideband display that's logged by the Wolf EMS. UEGO is just there as I had it wired in prior to standalone, figured I'd compare the two.
Why would I need a logger? It has peak memory and warning on the gauge, and I know where I want to be (I believe I read anything over 7psi AFR should be 11.0). The gauge memory should be enough, or I have a co-pilot. =)
