Where to put boost gauge line?
I just got an autometer boost gauge and I don't know where to tap into the vacuum line. Also where would be the best place to connect to a 12v wire for the light? Thanks for the help
run a tee off of the KLR line under your glovebox. it might be easier to remove the glovebox first. As for the 12v, take it from the illumination wire from your stereo.
remove the carpet from passangers side (under the glove box), then unscrew and open the wooden "door", and you should be able to see both the DME & KLR boxes. The original boost gauge line starts from the behind of the KLR box.
Shouldn't be too hard to find.
check this thread:
<a href="http://forums.rennlist.com/forums/ultimatebb.php?ubb=get_topic;f=18;t=003966" target="_blank">http://forums.rennlist.com/forums/ultimatebb.php?ubb=get_topic;f=18;t=003966</a>
