Metal shavings in blown Bypass valve?
![Angry](https://rennlist.com/forums/images/icons/icon8.gif)
I took off my bypass valve the other day and noticed that there was aluminum shavings in it.Upon further inspection I took the IC out and noticed that in the bottom of it there were pieces of chewed up metal.I took the turbo out and it spins freely and there is a little play in it also.Also the hot side comp.fins are really chewed up.
Where can these metal pieces/shavings come from?
BTW I sent the turbo to Lindsey to get it rebuilt and to see of he could ID the metal pieces found in the IC.
<img border="0" alt="[cheers]" title="" src="graemlins/beerchug.gif" />
Thanks,
Thanks,
![Wink](https://rennlist.com/forums/images/icons/icon12.gif)
No, Everything on this car is stock, but it has been neglected for the past 10 years.I think it was just my turbo that went, but I am not sure since about the same time the car wouldn't start.
Thanks,
Thanks,
Take a look at the inside bolts (3 of them) that hold the air filter box to the AFM.
Especially the lower forward one. That is hard to put a standard wrench on it to tighten and more than one guy has done a poor job of tightening and had the bolt back out and get sucked into the turbo. Turbos don't like eating steel bolts. <img border="0" title="" alt="[Eek!]" src="eek.gif" />
![Smile](https://rennlist.com/forums/images/icons/icon7.gif)
The odd thing is the car ran great when I drove it the night before it did not start.It turns over normal, does not sound strange when tring to start.
The metal pieces aren't similar to a bolt or bearing or anything that I've seen except for maybe 1 piece looks like it maybe a fin of some kind but rather thick.The bolts to the airbox were loctited in when I put it on last summer.
Very Strange!!!
Very Strange!!!
