TD04E turbo vs K-29... Which is bigger and better??
I'm going to update the turbo in my 944.
And has several options. But just would like to know if somebody of you know about the K-29 and the TD04 turbos??
Wich makes more power?
Wich is bigger?
Wich is better for for road races purposes??
Thanks in advance!!
Wich is bigger?
Thanks in advance!!
You cna get the Garret TO4 series in as many combinatons as you can think of.Most of these will be smaller then the k-29.However, smaller doesnt neccessarily mean not as good.The Garret turbos are much more efficient then the KKK turbos.If you want a Garret that is similiar in size to a k-29 then you will need to look at a T-58, 62-1, T-66 or somethign along those lines. Beware though, most of these turbos can not be used with the stock intake manifold. You would need something like the intake manifold we build to make it work.Take care.
