Banjo Bolt/Hose replacement
I installed my reliaboost-II today (wow! what a difference). I noticed the hose coming off the banjo bolt is a bit brittle and cracked. I want to replace it but the fitting for the banjo bolt is crimped on from the factory. Can this piece be used on a new hose or do I have to buy the whole thing as 1 unit? If so, where is the cheapest place to get one? A local performance shop recommended I go to a shop that specializes in custom hydraulic fittings.
Just cut off the part that looks crimped. It's just a thin outer cover. This leaves you with a reusable barbed banjo bolt. Depending on hose size, you then can add a hose clamp if necessary.
